Discrete Phase & Mass Flow Rate
Old   December 2, 2011, 18:57
Default Discrete Phase & Mass Flow Rate
Gabriele Mosca
MagnusZeus is on a distinguished road
I hope that someone can help me for this problem. I would simulate the presence of particles inside a chamber but I have some difficulties to understand how I have to set the mass flow rate. For my chamber I have a surface with the property of mass flow inlet and through it a gas with mass flow rate called for istance A is injected. If physically I have to satisfy a condition for which mass flow rate of gas must be reduced to (A-5%A) and a mass flow rate particles of 5%A with a given diameter must be injected, using the discrete phase model do I have to reduce the mass flow rate of the gas? Or do I have to inject the same mass flow rate A for the gas plus introducing a mass flow rate 5%A of particles in order to avoid depressurization???
Thanks!
MagnusZeus is offline   Reply With Quote
mass flow rate not conserved in turbomachine, interface defined wrong? wildli FLUENT 3 September 15, 2022 13:19
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 22:02
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 15:10
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 03:19
