Tecplot reading particle data error
Old   December 2, 2011, 03:58
Question Tecplot reading particle data error
Ali
ali hemmati is on a distinguished road
I have a problem with reading particle data into Tecplot. I choose "Include Particle Data" in "File>Import Data>Fluent Data Loader", yet after reading Fluent dat files Tecplot says:
Parse error while reading reading particle data section (section 116). Expected ')' found.
I have no idea what it means, because I have defined Injections and every thing is OK in Fluent. Fluent itself also shows particles with no error.
ali hemmati is offline   Reply With Quote
Old   February 13, 2016, 07:17
Default Update
Jakob Heide
jheide is on a distinguished road
Hello, I have the same problem.
Did you find a solution?
Thanks,
Jakob
jheide is offline   Reply With Quote
particle data, tecplot
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 06:17
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
