November 29, 2011, 11:48 |
Specifying Back Pressure in Fluent
Rep Power: 15 |
I am trying to set the static back pressure for a converging-diverging nozzle in Fluent using the 'Pressure-Outlet' boundary condition. I have put the desired back pressure as the "Gauge Pressure" when I specify the boundary conditions. But when I produce a graph of my results, the static pressure at the outlet according to the graph is not the same as the static pressure that I specified as my boundary condition.
Does anyone know how I can set up my case so my back pressure from the graph equals the back pressure I set for my boundary condition? Thanks in advance. |
November 29, 2011, 11:58 |
since you get the pressure field as solution of RANS therefore fluent does not strictly enforces the outlet condition. Although it try to enforce specified outlet condition, but to extent it does not violate interior solution.
November 29, 2011, 12:21 |
Rep Power: 15 |
Is there any way that I can make it stick to this back pressure? I am trying to do the same case that I did for an experiment so I can compare the two, but I cant get the boundary conditions to be the same.
Thanks for such a swift reply. |
November 29, 2011, 12:25 |
i believe that in experiment your boundary is placed at far downstream. Therefore put your boundary at downstream where your boundary condition does not vary, in other words it is far far downstream and therefore does not influenced by flow from nozzle
November 29, 2011, 12:29 |
Rep Power: 15 |
So there is no way I can specify the static pressure at the outlet plane and run my simulation from this? I have done some tutorials and they have specified the back pressure using the method I have used, so I thought it would be best to follow their method.
November 29, 2011, 13:23 |
Rep Power: 15 |
I specify 61080Pa and Fluent returns around 52000Pa.
fluent back pressure |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 12:35 |
How to give pressure inlet in Fluent | Vijayaragavan | Main CFD Forum | 1 | December 17, 2007 10:40 |
Calculation of pressure forces in Fluent | Maharba | FLUENT | 2 | June 29, 2007 02:14 |
Calculating Centre of Pressure within FLUENT | Matt | FLUENT | 1 | March 5, 2006 09:29 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
