#21 |
Rep Power: 7 ![]() |
#The reverse flow occurs at the top of the last louver (next to the outlet)in double skin facade.How can i fix this error message in ansys fluent?
#22 |
Rep Power: 18 ![]() |
Reserve flow is no error - it's only a "hint" for you.
You could adjust the back flow in the boundary settings. In other software I would enable extrusions or "old school" you add it in your model in front of the meshing ![]() /edit: Mesh quality you should anyways. |
#23 |
taba
Rep Power: 8 ![]() |
it is very useful to reduce the urf of momentom
#24 |
Santosh Kumar Sahu
Rep Power: 0 ![]() |
I am trying to solve a cryogenic problem where density of gas changes with temperature. When i change the density property it is showing reverse flow in pressure outlet, but if i use constant density there is no reverse flow. |
#25 | |
Garikai Marangwanda
Rep Power: 12 ![]() |
reverse flow |
reversed flow in xxxx faces on pressure outlet | franzdrs | FLUENT | 8 | January 4, 2020 20:12 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
CAN'T CONVERGE WITH REVERSE FLOW AT OUTLET! | XIAOYI LI | FLUENT | 11 | September 14, 2012 16:43 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
