Heat Transfer Coefficient
Old   November 18, 2011, 12:26
Default Heat Transfer Coefficient
Dilraj Sehmi
Dilraj is on a distinguished road
Hi all,
I am running a simple analysis of turbulent forced convection (cooling flow over a plate at high temperature). Right now I am struggling to get the HTC to match with the relevant published correlations when using the mean film temperature for the properties. When I use the properties at inlet temperature the match is a lot better.
The method I am using to obtain the HTC is to run two analyses and use the difference of the wall heat flux from both divided by the wall temperature difference.
I expect a small error but I am about 50% out at the moment. I am using the low-Re SST turbulence model and have a y+ of 1. I am also reasonably confident that the solution has converged.
Any help on the matter would be useful. Thanks!
Dilraj
Dilraj is offline   Reply With Quote
Old   November 20, 2011, 07:14
xrs333
xrs333 is on a distinguished road
Hi, Dilraj,
The ref. and qualitative temperature should be same as those used in published correlations, usually the bulk temperature, which is often close to inlet temperature, instead of film temperature should be used, some correlations use average temperature, arithmetical or logarithmic.
xrs333 is offline   Reply With Quote
Old   November 21, 2011, 04:54
Dilraj Sehmi
Thanks for the reply xrs333,
I am using correlations that suggest the use of the mean film temp for the properties. However when I compare the numerical results to the published correlations there is a much better agreement with the correlation using properties at the bulk temperature.
Is there an error with the numerical simulation or is this inaccuracy to be expected?
Old   November 21, 2011, 05:36
xrs333
Sorry, I misunderstood the words 'mean film temperature', my English is so poor...
In heat transfer, the mean film temperature is defined as algebraic average of bulk temp and the wall temp.
Old   November 21, 2011, 06:17
Sandeep
sandeep_tu is on a distinguished road
I didnīt exactly understood your problem other than you want to calculate the HTC. Normally in Fluent for HTC calculation it takes the reference temperature the value which you give in reference conditions panel.
sandeep_tu is offline   Reply With Quote
Old   November 21, 2011, 07:17
Dilraj Sehmi
Thanks for the reply guys.
What I've done is I have extracted the total surface heat flux from the cfd analysis and used the Nusselt Number correlations available on this page http://courses.cit.cornell.edu/fluent/plate/step6.htm.
When I plot the curve for the correlation against the curve for the cfd analysis there is a significant difference.
I have evaluated properties at the inlet temperature.
I have tried changing the analysis type to compressible but it doesnt seem to make a huge amount of difference. Any other ideas?
Cheers.
heat transfer coefficient, htc, turbulent
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 17:29
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
