Air flow simulation in volume with fan and opening
Old   November 14, 2011, 18:44
Default Air flow simulation in volume with fan and opening
KK
koziymf is on a distinguished road
Good day!
I have a simple task to model the air flow inside the volume of gas sampling chamber. Chamber contains 1 fan with known volume flow/static pressure curve, and 1 opening for inflation the gas from the outside.
My question is - what boundary conditions I need to set for this structure? Exhaust fan for fan and inlet-velocity (with 0 velocity) for opening? Or use outflow for opening?
The final task is to determine the volume air flow the fan will produce taking into consideration the resistance of flow channel and consequent pressure drop.
Thanks a lot in advance!
koziymf is offline   Reply With Quote
air flow simulation, ansys, fan, fluent
Simulation of Fan in Open Atmoshphere shraman_goswami CFX 2 April 23, 2009 06:35
Propeller Fan Curve Simulation Teng_YJ FLUENT 2 February 16, 2009 20:37
urgent pressure condition for axial flow fan VIPUL FLUENT 0 October 24, 2008 03:01
Fan dilemma Jenny CFX 7 February 11, 2008 13:17
Help setting up pressure function across opening Jenny CFX 3 October 18, 2007 01:16
