November 11, 2011, 11:19 |
Set current time step
Rep Power: 15 |
I did my first dynamic mesh is an IC engine.
When I did mesh motion, I got some error at 333 degrees. Now My display is showing the grid at 33 deg. How can i put it back to o deg, ie time step zero. I did another one and got my results. But I can see only the last time step contours. I want to see the contours at diff time steps. ( I Saw some threads like this. bUt didn't get a good ans) I don't want a animation. I don't want to save diff case files for diff time steps. I want to see the contours in the same display window at diff time (or diff crank angles). |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 22:51 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
Time step, Number of time step, Maxximum Iterations per time step | sandisk | FLUENT | 0 | July 18, 2011 03:57 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 06:55 |
Changing deltaT of current time step | olwi | OpenFOAM Running, Solving & CFD | 1 | April 30, 2009 05:55 |
