Reversed Flow for a tenth slice of a rotor
Old   November 7, 2011, 12:29
Default Reversed Flow for a tenth slice of a rotor
Michael Creaven
neptunemmx is on a distinguished road
I am modelling a 10 bladed rotating rotor, at 25m/s and rotating at 2800rpm. My grid is one tenth of a full cylinder and extends about 10 diameters in front of the rotor, and about 25 diameters behind the rotor. I am using periodic boundary conditions on the sides and pressure inlet, and pressure outlet on the inlet and outlet respectively. I am getting reversed flow on the outlet though. I have tried slowly increasing the rotation from 0 to 2800rpm yet I still get reversed flow at 1000rpm. Also I have tried solving this with the first order solver but I still get reversed flow before I switch to second order.
Any help would be much appreciated.
neptunemmx is offline   Reply With Quote
Old   November 7, 2011, 13:24
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
It is normal with Fluent, dont worry
Far is offline   Reply With Quote
Old   November 7, 2011, 13:46
Michael Creaven
For this particular case I am running the inviscid solver, which is why I am confused that I have reversed flow.
Old   November 7, 2011, 14:09
Far
Sijal
well for my case, I kept the boundary conditions, mesh, flow scheme, inlet & outlet boundaries and other things same/similar for CFX and Fluent but still I get reversed flow message in Fluent simulation
Old   November 7, 2011, 14:16
Far
Sijal
are you modelling rotor in free stream? if not then place inlet at one chord upstream and outlet at 1.5 chord downstream
Old   November 10, 2011, 12:49
Michael Creaven
I am modeling it in the free stream at 25m/s. As I have it setup and using 1st order discretization I can converge 5 orders of magnitude(1e-5) without reversed flow. However using 2nd order I get reversed flow and I cannot converge more than 1 order of magnitude. Could it be an issue with the boundary conditions? I have setup my pressure inlet and outlet so that the flow is 25m/s (the desired frestream velocity), do I need to some how account for the affect the rotor will have on the pressure, i.e. increase or decrease the velocity?
Old   November 10, 2011, 18:18
Martin H.
bobmalaria is on a distinguished road
Maybe you can lower the pressure relaxation factor in the solution control settings.
usually reversed flow can be tollerated if it is far enough away from the region you are interested in. maybe putting the outflow further away helps
bobmalaria is offline   Reply With Quote
Old   November 11, 2011, 00:44
Far
Sijal
did you specify the flow direction = normal or x = 1, y = and z = 0
Old   November 15, 2011, 23:11
Michael Creaven
I have specified the correct direction on my boundaries. Also I have extended my domain to 80 diameters (60 chord lengths) behind my geometry. I understand that reversed flow is ok, however I think that in my case it is stopping my solution from converging since the iterative residuals only converge to 1e-2.
Thank you for the help
Old   January 6, 2012, 13:03
Emma
emmkell is on a distinguished road
Is reversed flow at the outlet normally a cause for non convergence? I want to reach a convergence of 1e-03 but the solution wont converge at the moment.
I know moving the outlet to a place where the reversed flow disappears is an option for removing it, but i have a high node count already and so woudl prefer to not add additional cells.
emmkell is offline   Reply With Quote
Old   January 30, 2012, 14:51
Michael Creaven
I think that as long as you are not assuming that the flow is inviscid(i.e. using a turbulence model) it is ok to have reversed flow.
reversed flow, rotating cylinder
Reversed Flow in Fluent Analysis L. Hamid FLUENT 2 November 7, 2011 04:14
Reversed flow at pressure outlet Seeker Phil FLUENT 9 January 2, 2010 06:21
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
reversed flow Sastry FLUENT 5 March 22, 2007 09:05
Reversed flow on external aero problem Ben FLUENT 2 August 22, 2006 11:05
