Error in reading Fluent 13 case file in fluent 12
Old   November 6, 2011, 00:14
Default Error in reading Fluent 13 case file in fluent 12
Apurv
apurv is on a distinguished road
Hi all,
I am facing difficulty in reading a fluent 13 case file in fluent 12. The following error comes when i try to read the file:
Error: Error reading "I:\case_conv-1-0.01.cas".
Error Object: #f
Error: %non-conformal-mesh?: invalid grid
Error Object: #f
I have also tried reading the same case file on a cluster and fluent 12 running on linux. I get the following error.
Error: %prf-set-var: invalid flonum
Error Object: (50)
Error: Error reading "xxx.cas".
Error Object: #f
However, there are no issues in reading fluent 12 case in fluent 13. But when the file compiled in fluent 12 is run on fluent 13, it cannot be run again in fluent 12.
Does anyone has any idea how to solve this issue. Any help is greatly appreciated.
Thanks,
Apurv
apurv is offline   Reply With Quote
Old   November 7, 2011, 00:05
fox000002's Avatar
fox000002 is on a distinguished road
Fluent is downward compatible.
Fluent12 cannot read Fluent13 case file.
fox000002 is offline   Reply With Quote
Old   July 12, 2013, 08:46
Vjoess
dinesh is on a distinguished road
yah this is the only reason why its not reading it properly bcoz of compatability issues. you have to read your file in a version equal or higher. But remember that once you read it in higher version it wont run back in lower version. So keep your file safely before going for run.
dinesh is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
