Text command for report surface integral
Old   November 2, 2011, 15:54
Default Text command for report surface integral
jianbo jiang
jbjiang is on a distinguished road
Dear all,
I have a question about report surface integral.
I have a large number of fluent case/dat results. I want to batch-process the results and get the surface integral of heat flux through the walls.
For every cas/dat, the name of walls are different. In the menu "Reports", if "Fluxes" is considered, there is one option in the text command "all boundary/interior zones [yes]", so I can output the results for all the boundaries. But if I want to output "surface-integral" by text command, there is no such option to output all the boundaries.
Theoretically, I can manually input the name of boundaries case by case in jou file, but the problem is that there is a large number of Fluent cases. Does anybody have the experience to output the surface-integral by jou file without inputting the name of boundaries beforehand?
Thanks!
best,
jjb
jbjiang is offline   Reply With Quote
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
How can be calculate a surface integral in the finite element method? HectorRedal Main CFD Forum 3 March 13, 2015 09:25
Calculating forces on a non-closed surface ScottN FLUENT 0 March 1, 2011 18:18
Surface Integral - Mass Flow Rate Venkatesh V FLUENT 3 October 10, 2008 17:18
Normal - Helical Surface m. malik Main CFD Forum 3 February 3, 2006 13:56
