October 14, 2011, 02:54 |
Fluent Solver
neville
Rep Power: 15 |
For real gases flow simulation is pressure based or density based solver more accurate ?
October 14, 2011, 23:21 |
Lucky
Rep Power: 66 |
You can do either pressure based or density based solver for Real Gases, since they do on affect how the gas properties are calculated.
The choice of whether to use pressure or density based solver to begin with is more important. In general, stick with pressure based for incompressible and density based for highly compressible flows (unless you know your flow needs density based for whatever reason, go ahead and use it). |
FLUENT Solver i strange | BastiL | FLUENT | 1 | July 14, 2008 17:27 |
Changing from STAR to FLUENT - Solver Troubles | BastiL | FLUENT | 0 | February 15, 2008 17:41 |
help required in using six dof solver in fluent | Shah | FLUENT | 1 | February 25, 2006 12:31 |
What's a UDF? | Farooq | FLUENT | 5 | December 9, 2003 07:52 |
Fluent solver question ? | prasat | FLUENT | 1 | August 25, 2003 10:27 |
