Problem in finding files after exporting
Old   October 11, 2011, 08:43
Question Problem in finding files after exporting
Swapnil
optimus_jack031 is on a distinguished road
dear every1,
I am using fluent-gambit for the first time. I am learning it by practicing the tutorials provided. My problem is that after meshing the geometry and exporting it via 'File>export>mesh' i am not able to read/locate its corresponding 'case' file in fluent. Its basically a 3d problem and i opted for Generic solver
Please help me out...
i know it must be trivial issue but i am just not able to get it...
optimus_jack031 is offline   Reply With Quote
Old   October 12, 2011, 03:10
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
gambit export doesn't provide any case file, but a mesh file (in your case *.neu)
To find your file, it is located where you started gambit.
If you started gambit in C:\test, but you opened a .dbs file in C:\temp, then your export will be in C:\test
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
case creation, mesh export
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
Problems with exporting and importing CAS files .. Danny FLUENT 0 September 16, 2005 11:47
Exporting problem from parallel solvers Kong FLUENT 6 May 4, 2005 12:55
Exporting GAMBIT files in 'plot 3d' format Jeff FLUENT 0 November 22, 2001 20:52
[making animations] fclose fails to close files? Mika FLUENT 0 March 30, 2001 09:19
