Problem with centrifugal force
Old   October 11, 2011, 04:56
Default Problem with centrifugal force
Norger
norger is on a distinguished road
Hey,
I read in this article: http://www.cfd-online.com/Forums/flu...ting-wall.html that the "centrifugal force gets calculated automatically during solution" but in my case it does not.
My part is a bin which has ducts perpendicular to the rotation-axis and there should come out the fluid.
The problem is that not each duct give out the fluid. The half of them push out and the other half suck in the fluid?!?!
--> The centrifugal force does NOT get calculated automatically during solution.
Thank you for your help
norger is offline   Reply With Quote
Old   October 12, 2011, 02:55
Norger
Did nobody has the same mistake?
Problem with centrifugal pump calculation Michiel Main CFD Forum 2 June 17, 2012 22:32
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 11:25
Problem with surface pressure integrals javier FLUENT 0 February 9, 2004 16:09
gravitational force for free surface flow Jongtae Kim Main CFD Forum 1 July 2, 2000 12:57
