Heat transfer across closed cylinder
Old   October 5, 2011, 10:30
Default Heat transfer across closed cylinder
Dav_Mechanical is on a distinguished road
Hi, I am just a beginner in CFD and I am using fluent 6.3.26 as CFD software.
I am trying to perform a simple 3d heat transfer analysis across a closed cylinder with air inside in order to get more practice but I am not sure if I am doing the simulation correctly.
One end of the cylinder is heated to a high temperature T1 while the other end is at room temperature, T2. There will be of course conduction across the cylinder walls and convection throughout the air inside while radiation will be assumed negligible.
Through the boundary conditions option, I have set the hot end wall to a temp of T2 while the cold end wall is set at T1 but I dont know how to include convection of the air inside since the air is the the default-interior zone.
Can anyone help me on this specific case or point me to a helpful guide?
Thanks!
Dav_Mechanical is offline   Reply With Quote
Old   October 5, 2011, 16:16
Mohammad
m2montazari is on a distinguished road
hi,
take a look at http://www.cfd-online.com/Forums/flu...tml#post323568
it may help. make your problem more clear if you had problems yet.
yours,
mohammad
m2montazari is offline   Reply With Quote
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 18:31
need papers on heat transfer George Main CFD Forum 0 November 27, 2008 08:42
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
axial flow around a cylinder -heat transfer model? Ralf Schmidt Main CFD Forum 1 March 21, 2006 09:54
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 06:09
