Hussam Jawad
Rep Power: 15 ![]() |
Hi all ... I am modeling a porous layer undelying a fluid layer and I just knew that I can produce a movie for my model to represent it in my university. I would be very thankful if any one could inform how I can do a movie for the stream lines in my model.
Jack cosby
Rep Power: 14 ![]() |
you can use one of these methods to create an animation off of your solution(these are the ones that I know of):
1-use the animation feature within fluent which stores a series of files and then creates the animation 2-write a scheme/journal loop that loads the dat files(that you have saved every n time-step) and captures the screen/image and then get an animation out of that(read the fluent manual) 3-you can use posprocessing software such as tecplot which is pretty easy to use and produces good results. |
Hussam Jawad
thanks a lot.
High quality movie from CFX post | HMR | CFX | 0 | February 17, 2011 20:31 |
Fidap to Fluent | Ravi | FLUENT | 3 | July 10, 2008 13:31 |
user_sub FIDAP doesnt work | semetay | FLUENT | 3 | July 22, 2006 19:51 |
2D Transient flow using Fidap | Young | FLUENT | 1 | July 2, 2004 12:02 |
Variable Density - Free Surface with FIDAP | Vitaliy Pavlyk | FLUENT | 7 | May 2, 2000 15:56 |
