high CPU load with no computation going on & Pressure coefficient output problem
Old   September 30, 2011, 06:25
Post high CPU load with no computation going on & Pressure coefficient output problem
sgsergersg
spetsnaz26 is on a distinguished road
Hi, everyone. I'm new to Fluent. On my 4-core, 8-thread machine Fluent somehow uses the same CPU resources regardless of its state (computing or idling). I noticed this when once, after computation has converged, I checked Window's task manager and found to my surprise that 8 Fluent processes were still very much there and took all my CPU. Is this...normal? What CPU resource could Fluent possibly need when it's idling??
Another, seperate, problem with output data:
After calculating an inviscid, incompressible solution on an aircraft 3D flow field, I checked out Fluent's built-in display tool and was again suprised: instead of being on the order of -5.0~+5.0 that I expected to see, pressure coefficient spans the incredible range of -2500~+3500. I checked static pressure and found it spans from -2200~+1800. While the later could be "gauge pressure", how could the calculation of Cp be wrong?
spetsnaz26 is offline   Reply With Quote
cpu load, pressure coefficient
problem in the CFX12.1 parallel computation BalanceChen ANSYS 2 July 7, 2011 11:26
natural convection mehrdadeng CFX 10 February 25, 2011 06:25
Tutorial problem: "rhopSonicFoam - shockTube" with high pressure shangzung OpenFOAM 0 November 1, 2009 14:07
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
Problem in Result of the pressure coefficient Ken Choi Main CFD Forum 2 March 15, 1999 05:15
