fluid movement with friction inside a pipe
Old   September 14, 2011, 09:04
Default fluid movement with friction inside a pipe
hamid
hamid1 is on a distinguished road
how can one model a movement of fluid inside the tube with considering a friction between fluid and solid (wall of tube)?
thank you
hamid1 is offline   Reply With Quote
Old   September 15, 2011, 08:50
hamid
Nobody were aware of the answer?, or even some clue would be very much appreciated,
thank you
Old   September 15, 2011, 10:30
zhouquan
jayiba322 is on a distinguished road
thank you
I guess the stress on the wall can perform the frictional effect
jayiba322 is offline   Reply With Quote
Old   September 15, 2011, 12:30
Amir's Avatar
Amir
Amir is on a distinguished road
thank you
Dear Hamid,
When you set no-slip condition or shear at walls, you're implicitly consider friction, but if you mean contribution of wall roughness in friction, you've to know that wall roughness doesn't have any effect on shear stress in laminar regime but in turbulent regime you can set it in FLUENT; in this regime both wall function and roughness certainly affect shear stress.
Bests,
Amir
Amir is offline   Reply With Quote
Freely solid rotation inside a fluid Juan Maria CFX 0 April 10, 2008 08:59
CFX Fluid Domain Movement greg CFX 1 March 25, 2007 09:08
non-newtonian fluid and movement BC's biomedical sompong FLUENT 0 March 3, 2007 06:35
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 02:40
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
