modeling solids feeding to air flow
Old   September 14, 2011, 03:47
Default modeling solids feeding to air flow
Angie
Angeline is on a distinguished road
Hi Guys,
My case is the gravity feeding of solids from a cylindrical container (Height ,h)to air flow inside a pipe. How can i model this in fluent. I want to find out the velocity profiles of the solids . What boundary conditions should I use. Initially the solids are at rest and when the valve is opened , solids fall due to gravity to gas flow.
Someone kindly help me.
Angeline is offline   Reply With Quote
Old   September 14, 2011, 13:01
Harpreet
Harpreet is on a distinguished road
try using DPM model, and activate gravity in operting conditions along the direction of flow desired.
Harpreet is offline   Reply With Quote
Old   September 15, 2011, 02:14
Angie
Thanks Harpreet for your reply. But what about the boundary conditions.what will be the initial velocity of solids.
Old   September 15, 2011, 13:48
Harpreet
although i haven't tried, but i think if you could the unsteady case with initial velocity of solid particles set to zero, it should work. For the boundry conditions more description of your problem is required.
Simulation of air flow in a chamber Issa CFX 3 November 23, 2009 18:16
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
3D-Simulation of Water Flow From Nozzle into Air Navin Sampath FLOW-3D 2 February 26, 2009 11:46
mold flow modeling Pei Hsieh Main CFD Forum 0 May 4, 2005 11:08
Increasing air flow using fans jim sanders FLUENT 0 January 10, 2002 10:24
