Non-Reacting Mixture in FLUENT
Old   September 12, 2011, 19:51
Default Non-Reacting Mixture in FLUENT
NormalVector's Avatar
NormalVector
NormalVector is on a distinguished road
I'm trying to model the flow of a transient, non-reacting binary liquid mixture in a closed chamber and I ran into a question. I've set the individual components and their properties and then I've set the mixture properties as weighted mixing laws using the individual component's properties.
My question is: where should I set the mass fractions of my mixture? I've tried setting them under "initial conditions" in the solution initialization panel but I don't think the residual is showing up correctly. I expect to have a continuity residual for the bulk species as well as one for the remaining species. The continuity residual shows up correctly but the residual for the other species stays relatively constant at around 1e-12.
Any thoughts?
NormalVector is offline   Reply With Quote
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
In Fluent 6 how to include Air-nitrogen mixture for numerical modelling k.anand FLUENT 0 April 7, 2011 17:06
Simulation of steam (CO2 and Water vapor mixture) flow through nozzle using Fluent. Jimmy FLUENT 0 March 2, 2011 13:30
Problems with text command interface of Fluent Pascal Anschau FLUENT 2 November 9, 2005 08:25
Mixture Properties-auto update by Fluent? Julie FLUENT 1 August 23, 2002 23:40
