Selection Surface for contour plot by journal file |
September 12, 2011, 12:58 |
Ghazlani M. Ali
Rep Power: 29 |
I've been doing some iterations on a cluster using a journal file. After getting my solution i decided to look at the contours plot for the total pressure. I can't do that using the GUI interface since i'm giving a journal file so the cluster can read it and execute it . the command line for visualizing the contour plot of the pressure are:
/display/contour/total-pressure 30000 70000 [Pa] The only problem i have is the selection of the surface where i will plot my contours. How can i do that ? my surface name is "interior-29" of curse i will take a screenshot using the save-picture command at the end Thanks in advance. |
contour, journal file, plot, surface |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
plot in file with journal (text commands) | Asashi | FLUENT | 1 | August 21, 2006 08:08 |
