Eulerian granular flow using PBM
Old   September 7, 2011, 10:48
Default Eulerian granular flow using PBM
Li Huang
lihuang is on a distinguished road
Dear friends,
I am using Population Balance Model coupled with FLUENT mixture model to simulate the dispersion of solid particles in the wake of moving cars. The simulated volume fraction of the secondary phase looks reasonable, which extends backwards to a certain distance behind the car. But when I plot the Population Balance variables (such as Bin Fraction and Number Density), they don't go far behind the car. It seems the model has no problem in modeling the dispersion of particles as secondary phase, but when it comes to each bin of particles, the model does not give the dispersion right.
Can anyone help?
Thanks
lihuang is offline   Reply With Quote
Old   September 7, 2011, 14:23
koteswari
mdsvjpk is on a distinguished road
can u provide the details of intial conditions for inlet and intialisation of particle size distribution
mdsvjpk is offline   Reply With Quote
Old   September 7, 2011, 14:56
Li Huang
I have a velocity inlet of air at a so-called INLET surface (v=-28m/s, about 10 m in front of a stationary car) and a velocity inlet of particles at tailpipe of the car (v=-10~-20 m/s). Particle size is around 80 nm to 800 nm in 6 discrete size bins. I initialized the model from INLET with 0 volume fraction of particles and 0 fraction for each bin.
Old   September 8, 2011, 01:18
koteswari
i think, u should not initialise that with zero volume fraction try with that and let me know the result
Old   September 8, 2011, 15:06
Li Huang
Thanks very much for your suggestion. It works for a single component particle scenario. I initialize the model with 0 total particle volume fraction and a prescribed size distribution for bin volume fractions.
However, when I try with two components for particles as mixture, the plot of particle->species->Mole fraction of each component shows 0 for the whole domain. Even when I tried to initialize the model with small fraction of total particle phase volume fraction, I had no luck. Could you point some directions to me please?
Thanks
Compressible flow with the Eulerian model AdN FLUENT 7 October 8, 2015 00:00
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Help for granular flow simulation Derek Jing FLUENT 0 February 22, 2002 21:50
about granular flow model daninwin FLUENT 0 January 19, 2001 04:47
