Modeling the Sandia flame D with EDC
Old   September 1, 2011, 06:21
Default Modeling the Sandia flame D with EDC
Christoph_84 is on a distinguished road
Hallo,
I tire to model the Sandia flame D with EDC to validate the EDC Model. I tried different reduced mechanisms Based on GRI 3.0, converted the Fortran code to c (f2c) and implemented that Mechanisms with a net reaction rate UDF. But the 12 Step mechanism from the Sandia homage crashes after some calculation Time (negative mass fraction), and the other mechanisms from J. Hewson and M. Bollig works. The Flame ignites on high gas temperatures, but when I set the right temperature the flame extinguishes (transient calculation with 1 interration per Time step).
Did anyone of you have success by calculation such a Flame with EDC? Other combustion Models in Fluent are already tested:
-Flamelet: standard model we use for calculations, but the combustion products can’t react (reducing ore with CO for example)
-Eddy Dissipation: no chemical kinetic, just turbulence => to short hot Flame
-Eddy Dissipation/laminar fine rate: same effects line EDC
-PDF Transport: needs to much calculation time
So we think that EDC or Eddy Dissipation/laminar fine rate is that what we need as addition to the Flamelet model.
Kind regards,
Christoph
Christoph_84 is offline   Reply With Quote
Old   September 18, 2011, 21:24
Default UDF source file
Pei
Pei
Pei is on a distinguished road
Hello Chris,
Could you please share your UDF source file? I am also trying a n-heptane reduced mechanism and found some abnormal.....
Cheers,
Pei
Pei is offline   Reply With Quote
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 10:39
premixed flame modeling problem peiyong wang CFX 1 July 18, 2008 13:02
Modeling Heat Generated by Gas Flame (CFDesign) Ross Fotheringham Autodesk Simulation CFD 2 October 30, 2007 12:25
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 15:49
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 10:21
