Which Turbulence modeling????
Old   August 31, 2011, 16:59
Arrow Which Turbulence modeling????
Pooya
Yapoo is on a distinguished road
hi friends,
I'm working on hydrodynamic analysis of catamaran hull in turbulence flow with VOF method in low Reynolds number (Shallow water).
please give me your suggestions about the best turbulence modeling for this problem.
Yapoo is offline   Reply With Quote
Old   August 31, 2011, 18:27
Jeremy LeFevre
jlefevre76 is on a distinguished road
How is the reynolds number defined for this system? Based on depth of the water, not the length of the hull? Also, it's a fluid-fluid interface problem, so I'm guessing you're mainly looking at the water side fluid mechanics?
My method of determining a turbulence model might not be the best, but usually I test 2-3 models that I think would work, and if they all give me similar results, I just pick one and run with it.
Anyway, more details might help if you want someone to reply who really knows what they're talking about!
jlefevre76 is offline   Reply With Quote
Old   October 2, 2016, 03:29
Hossein Mirabi
Hossein Mirabi is on a distinguished road
Hi Dear Yapoo
I believe it is better to use Reynolds Stress Turbulence Model. The RSM use 7 different transport equation, 6 equation for elements of stress tensor and 1 for turbulence dissipation rate. So this model estimate hydrodynamic parameters of flow anisotropically and it has more accuracy in compare with two-equation models like k-e and k-w. On the other hand it is a time-consuming model.
So if you have enough time and fast Processor, this is an ideal model for estimating turbulent parameters.
Hossein Mirabi is offline   Reply With Quote
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 12:48
Turbulence modeling for fan/compressor blading Jonas Larsson FLUENT 1 April 13, 2005 15:08
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 05:24
