Sequential solution of conservation equations
Old   August 30, 2011, 17:01
Question Sequential solution of conservation equations
N/A
cp_jef is on a distinguished road
I am currently working on an internal flow, conjugate heat transfer problem utilizing a UDF to vary the inlet velocity until a certain per-determined target is achieved. I am interested in knowing if there is a way to suspend the solution of the energy equation until the UDF has determined the required inlet velocity and (maybe) the continuity and momentum equations have converged or are close to convergence. I know this can be done manually by stopping the solver and enabling the energy equation, but I want the process to be automated as I have to solve a DOE with a large number of design points.
Thanks.
Regards,
John
cp_jef is offline   Reply With Quote
fluent, solvers, udf
About the solution of a simplified two-phase model maximus Main CFD Forum 3 October 25, 2005 13:03
Sequential calculation of Temperature and mass tra J.W.Ryu FLUENT 7 June 18, 2002 08:12
multigrid solution of 2d euler equations jim Main CFD Forum 2 May 21, 2002 05:05
Numerical Conservation equations for salt content Kourosh Hejazi Main CFD Forum 0 February 26, 2002 10:11
CONSERVATION EQUATIONS IN NONINERTIAL SYSTEM!!! zhang zhanwang Main CFD Forum 0 August 17, 1998 08:38
