droplet impact on a dry surface.... VOF again
Old   August 26, 2011, 20:20
Default droplet impact on a dry surface.... VOF again
rogerspass is on a distinguished road
Hi. All,
I know there are some topics related to this droplet impact on a dry surface using VOF. But I still get lost. My question is how to setup the boundary conditions.
In more detail, for a positive to the right and up respectively coordinate, I create a 2D rectangular face domain, 10mm (L) x 5mm (W), where a 2mm water droplet is located in the center. Both faces are using 0.1 interval size of mesh. I set the the four boundary as walls, also set the droplet as a velocity inlet. The multiphase (VOF) was used. Gravity is point to -Y. After setting a velocity (Vy = -1 m/s) for the droplet in Fluent and proceed the calculation. The droplet just did not move at all. Can someone shade me some light? Do I miss something else? Thanks.
rogerspass is offline   Reply With Quote
Old   June 27, 2016, 03:12
Default help
tawfiq
toufik08 is on a distinguished road
Hi rogerspass
Did you recieved any answer on your query, I have almost the same problem, if you know how to simulate droplet impact on solid surfcae please help me.
With best regards
toufik08 is offline   Reply With Quote
Inconstant Surface Tension on Interface in VOF Atieh FLUENT 0 February 9, 2007 03:37
VOF simulation free surface caused by gas inject rensb FLUENT 4 July 20, 2006 05:45
VOF and droplet impact simone marras CFX 4 July 13, 2006 06:54
Surface tension options for VOF models chapelle FLUENT 4 September 20, 2005 04:49
VOF and Droplet Formation saang Siemens 1 June 7, 2005 04:59
