Best choice for my setup ? Sliding mesh or single rotating ref frame ?
Old   August 23, 2011, 06:05
Default Best choice for my setup ? Sliding mesh or single rotating ref frame ?
Rockda Kasba
Rockda is on a distinguished road
I'm currently trying to set up a 2D Fluent case of water jet impinging a hot rotating cylinder.
In a first time, i decided to only focus on hydrodynamic (thermic is disabled) so i made a VOF case (2 phases, air/water).
What strategy should i adopt to solve this problem ? Should i use a sliding mesh, or a single rotating reference frame ?
You can find a pic of my configuration with this msg. We have the cylinder, meshed roughly which will rotate around Oz axis , and another meshed zone upper, which correspond to the "fluid" zone. The water jet will come from the upper extremity of the fluid zone and hit perpendicularly the cylinder.
The major difficulty i encounter is to handle the rotation of the cylinder ( i heard about, sliding mesh and single rotating frame , using interface in BCs and coupled wall..) Can someone explain me clearly these things and the one i should use in my case ?
Thanks a lot.
Rockda
Rockda is offline   Reply With Quote
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
Setup Cell Error in Fluent on Workbench tolu FLUENT 1 September 12, 2013 14:28
How I can setup Fluent for a Define_Profile on FZ? Nuno FLUENT 5 February 23, 2012 04:39
2D setup and 2D profile data file in CFX10 Se-Hee CFX 3 October 30, 2006 10:49
setup vof test problem Fang Jin FLUENT 1 June 14, 2005 09:27
