Moving Solid!
Old   August 9, 2011, 17:13
Default Moving Solid!
Shashank
shashank312 is on a distinguished road
How would you assign a translational velocity to a moving solid which is placed over a fluid region?
I tried doing a moving reference frame on both the solid and fluid regions. And I gave a negative velocity to the solid region and a zero velocity to the fluid region according to my project.
But when I solve and look at the velocity vs z-coordinate plots, I get a zero velocity in the solid region.
I hope somebody has an answer to this. Meanwhile, I am looking into the Fluent user guide for more help.
Thanks,
Shank
shashank312 is offline   Reply With Quote
Old   August 13, 2011, 13:44
Denis
_Denis_ is on a distinguished road
Hi, shashank312.I'd propose to use dynamic mesh technique. For this you've got to write a simple udf on C. Look for "modelling flow using dynamic mesh" in the user's guide.
What do you mean when you say "over the fluid region"? Is your solid object moving in vacuum? Air, for example, should be modelled as a fluid region as well.
_Denis_ is offline   Reply With Quote
Old   August 13, 2011, 15:38
Shashank
Thanks for the advice. But I solved it. It was more of a bug in Fluent. It does not calculate velocity in the solid. So, I tried putting a hot spot to see if it showed any impressions under the solid.
And what I meant by "over the fluid" was that my solid was plate was on the top of a channel in which fluid was flowing.
Dynamic mesh is not necessary. Moving reference frame works just fine.
Old   May 4, 2021, 18:58
Bodo1993 is on a distinguished road
Hi, would you please give me a hint on how to use moving reference frame instead of dynamic meshing to remove a wall from a fluid domain? Thanks
Bodo1993 is offline   Reply With Quote
Moving solid problem Mudblood FLUENT 0 June 10, 2010 13:11
how do I get a solid volume moving? Katariina CFX 2 March 28, 2008 05:50
moving zone interface betw. 2 touching solid bodie Mike FLUENT 0 September 21, 2005 06:23
solid suspension in moving liquid Jason FLUENT 4 October 27, 2003 19:59
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
