August 9, 2011, 09:40 |
Floating point error
Alex Poyser
Rep Power: 15 |
What does this error message mean? apparantly I have an invalid number.
August 10, 2011, 00:12 |
Stuart Buckingham
Rep Power: 26 |
Ouch! The dreaded floating point error!
Your solution may have blown up, and you may be getting huge (unrealistic) pressures/velocities/densities etc... What are you modelling? Maybe one of your BC's is wrong? Also, some solution methods are highly unstable, maybe try with more default methods (pressure based segregated with 1st order disc.). Also, are the residuals converging on a solution? If not, try halving your under relaxation factors. GOOD LUCK! |
polynomial thermophysical properties II | sebastian | OpenFOAM Running, Solving & CFD | 54 | November 21, 2019 07:12 |
Problem with UDF compiling for kTkLW model | Wantami | FLUENT | 0 | July 18, 2011 05:11 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
