simulation of piston motion inside a hydraulic cylinder
Old   August 6, 2011, 16:44
Smile simulation of piston motion inside a hydraulic cylinder
mohd
mosman is on a distinguished road
I am a student working on Fluent to simulate motion of a piston inside a cylinder.
The cylinder has two ports, one on the left and the other on the right end. The piston can take any initial position inside the cylinder. There will be three zones: solid zone (the piston) at the center ; two fluid zones, one at each side of the piston.
When pressurized oil inter the cylinder from one side (say left port) the piston will be forced by the oil pressure to move to the other side (right). The piston in turn forces the oil on its right side to flow out the cylinder through the right port.
I need C code from similar example to guide me.
or if any one of you can help me by any sort of guidelines.
My email address: m.osman6m@gmail.com
M.osman
mosman is offline   Reply With Quote
[snappyHexMesh] SnappHexMesh Mesh creating a Mesh inside a Cylinder? abu OpenFOAM Meshing & Mesh Conversion 1 April 4, 2017 10:57
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[snappyHexMesh] SnappyHexMesh Meshing inside a cylinder nammari OpenFOAM Meshing & Mesh Conversion 5 March 11, 2011 20:49
Motion of cylinder due to vortex shedding ACHILLEAS TSOMPANOS FLUENT 3 November 24, 2006 04:06
simulate a 4-stroke piston cylinder san CFX 3 October 11, 2006 14:28
