unchangeable continuity residuals in parallel computing
Old   August 1, 2011, 13:15
Default unchangeable continuity residuals in parallel computing
raymond
wlt_1985 is on a distinguished road
I am using parallel computing to have my simulation. The problem appears as remain unchangeable continuity residuals starting from beginning to the end (value almost 1.0). Compare to serial computing, the continuity reduce to certain amount significantly (value almost 0.01). Both results are totally different. Pls help me to solve the parallel computing problem. Thanks
wlt_1985 is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Cumulative continuity error large in parallel simulations xiao OpenFOAM 3 March 7, 2011 05:13
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
