Help needed in meshing for Solid to Fluid Heat Transfer
Old   July 27, 2011, 13:44
Default Help needed in meshing for Solid to Fluid Heat Transfer
Niaz Ali Ahmed
niazaliahmed is on a distinguished road
Help needed its urgent...
I have to simulate transfer of energy from Fluid to Solid and vice versa.
> I have created seperate meshes for solid and fluid (both .cas as well as .msh).
> I have made seperate boundaries where Interfaces have to be created between solid and fluid. I have created interfaces between solid and water contact.
> I have defined 2 Materials Al and Water and assigned them to Solid and Fluid Volumes.
> I have given initial conditions for water velocity, static temp etc..
> When I initialize the solver warns me that 'adjacent boundaries have different materials.'
Please suggest me if I had made mistake in meshing/Modelling Physics etc...
niazaliahmed is offline   Reply With Quote
Old   July 28, 2011, 09:21
Patty Streufert
pstreuf is on a distinguished road
Hi - you need to run a "coupled" solution in the thermal boundary condition panel for each interface.
pstreuf is offline   Reply With Quote
Old   February 22, 2020, 16:47
ghusoon riadh
gsnblueman is on a distinguished road
Good job good job good job
gsnblueman is offline   Reply With Quote
Help needed in using wall BC for heat transfer analysis of heat exchanger tubes hassaan FLUENT 2 June 25, 2013 08:05
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Heat transfer in oil (or other high Pr fluid) flows vishyaroon STAR-CCM+ 0 April 14, 2010 12:52
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 10:25
