July 16, 2011, 12:57 |
Help on Aerodynamic load
Lamboram
Rep Power: 15 |
I am asked to analyse an air flow across a cross section. The wind blows in a certain velocity and creates some loads on the walls of the surface under consideration. I will later use this load by the air for structural analysis.
I have made a 2D model, applied boundary condition, but how to bring out the load by the air flowing across. Please help. Lamboram |
July 20, 2011, 12:05 |
Rep Power: 15 |
Hi Ramesh
You need to extract the surface pressure distribution of the surface under consideration!! From there you can calculate your loads! Sincerely, A.D.E |
October 18, 2011, 20:24 |
Thank you !
Lamboram
Rep Power: 15 |
Thanks mate !! Appreciate it !!
Aerodynamic forces as Structural load | compeng | FLUENT | 2 | January 11, 2016 06:05 |
Aerodynamic noise analysis with CFX | famarcfd | Main CFD Forum | 0 | December 14, 2010 08:53 |
moving load problem | aditi chauhan | ANSYS | 0 | October 9, 2010 05:47 |
Strarting load step number | KtoTo | Siemens | 2 | June 21, 2007 10:01 |
Using load vector for parallel partitioning | Kevala | FLUENT | 0 | May 1, 2001 13:11 |
