Reynolds number
Old   July 15, 2011, 11:18
Default Reynolds number
pranab_jha's Avatar
Pranab N Jha
pranab_jha is on a distinguished road
Is the "Cell Reynold's number" same as actual Reynolds number (say in case of a pipe, based of pipe diameter). Which value should be used to determine if the flow is laminar or turbulent?
pranab_jha is offline   Reply With Quote
Old   July 15, 2011, 12:20
Amir's Avatar
Amir
Amir is on a distinguished road
Not at all, the length scale is different; in addition, the velocity of each cell is considered as velocity scale.
Cell Reynold's number is used for some numeric algorithms. (peclet No. )
Amir is offline   Reply With Quote
Old   July 20, 2011, 11:59
A.D.E is on a distinguished road
The cell Reynolds number is based on the local characteristics and in not the same as the flow Re!
A.D.E is offline   Reply With Quote
reynolds number
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Reynolds Number and Heat transfer Coefficient panos_metal FLUENT 0 January 7, 2011 07:37
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Low Reynolds Number k-epsilon formulation CFX 10.0 Chris CFX 4 December 8, 2009 00:51
Reynolds Number Matt CFX 0 February 25, 2009 06:40
