sudden jump in residuals
Old   July 15, 2011, 02:07
Default sudden jump in residuals
raymond
wlt_1985 is on a distinguished road
I did my model in unsteady case. I faced a big problem for long time. Each time further for next iteration, there was a sudden jump in residuals and it was going to reduce again repeatedly as attached. Please help me. Your opinion is appreciated.
wlt_1985 is offline   Reply With Quote
Old   July 15, 2011, 02:33
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
It's normal: it is due to the change of time.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 15, 2011, 02:45
raymond
Dear mAx,
Thanks for your help. Do you mean that sudden jump in residuals during change in time is correct for unsteady state? Do you mean that my model is acceptable with such trend of residuals? And is there any approach to reduce the sudden jump in residuals?
Thanks a lot.
Old   July 15, 2011, 06:08
-mAx-'s Avatar
Maxime Perelli
Yes the jump is correct
I would investigate for having more convergence on continuity/x-y-z-velocity residuals.
Maybe by reducing your time step
Old   July 18, 2011, 07:21
raymond
Thanks mAx,
I had gone through the model by having smaller time step. The trend was similar to result of larger time step. The results only might differ with different under relaxation factor or courant number or explicit relaxation factor under coupled algorithm. I had gone through few forum and some thread replied that those value under 'under relaxation factor or courant number or explicit relaxation factor'should not been changed for model accuracy. Is it true?
Best regards
Old   July 18, 2011, 07:49
-mAx-'s Avatar
Maxime Perelli
yes it will just give you faster or slower convergence
Old   July 18, 2011, 08:24
raymond
Thanks mAx. You definitely help me a lot
Old   June 25, 2014, 15:37
Joe
enayath is on a distinguished road
What about this huge jump in continuity residual?
it is related to transient k-e model
Thank you,
Hooman
enayath is offline   Reply With Quote
Old   June 26, 2014, 05:51
-mAx-'s Avatar
Maxime Perelli
see my first reply --> "It's normal: it is due to the change of time. "
sudden jump of value at interface wlt_1985 FLUENT 3 July 11, 2011 16:00
Jump in Residuals ryzd FLUENT 1 March 1, 2011 22:39
Jump in residuals under Linux mAx FLUENT 8 July 12, 2005 10:55
sudden plunge in residuals Shankar FLUENT 0 October 18, 2004 18:09
Fluent Parallel/Serial version..jump in residuals Sandeep Abhyankar FLUENT 4 January 10, 2000 10:57
