#21 |
Javi
Rep Power: 16 ![]() |
Hi guys,
I would like to know just taking a look to your journal files if is possible define a variable time step in the journal file. Something like: 100 iterations with x time-step 1000 iterations with y time-step Thanks ![]() |
#22 |
Javi
#23 |
Rep Power: 13 ![]() |
Hi
I am trying to do something similar but i need to select a surface at which the contours will be displayed. using display/set/contours/surfaces/plane-xyz It selects the plane but then returns contour surface id/name(2) [()] to select another surface, and this keeps on repeating with (3) (4) etc i want it to return to "/display" after it has selected the one surface i want. Any ideas on how to skip selecting more surfaces Thanks |
#24 |
OK i sorted this out, have to write () in the command as well at the end.
Next problem; error file saying no graphics functions available. I would think that is the actual case as well, but how did all of you guys end up getting a graphics (png jpg) file running the cluster which uses TUI. Am i missing something here. |
#25 |
Javi
Hi Hwet,
What was your startup setup and your grapics or gui options? Have a look at the picture below ![]() |
#26 |
Well, apparently the cluster at my university does not have a graphics card and hence no graphics driver, thats why this couldn't be done.
I wonder if there is another way? |
#27 |
Shuvam Mohanty
Rep Power: 6 ![]() |
yeah, that's a very good example of scripting. But can you tell me how to scripting an animation for a particular surface?
#28 |
Steven Xu
Rep Power: 0 ![]() |
hello, have you solved the issue before, I met the same issue now, I wanna output the animation through hpc , but the journal file maybe incorrect, can you support me ? My partly journal file is below
/solve/animate/objects/create no-animation animate-on contour-1 frequency-of time-step storage-type jpeg storage-dir "" /solve/dual-time-iterate 2 3 |
how to make hardcopy only while creating an animation | yubaibai88 | FLUENT | 0 | May 31, 2010 10:35 |
Creating Animation | Umm... | FLUENT | 0 | January 16, 2008 03:23 |
!Error creating animation sequence file | Brian | FLUENT | 1 | October 21, 2005 04:35 |
Creating an animation | Jason | FLUENT | 3 | May 18, 2005 05:13 |
error in creating animation | hadi | FLUENT | 6 | January 19, 2004 18:13 |
