July 12, 2011, 14:49 |
Mass flow inlet and pressure outlet issue
Nik
Rep Power: 16 |
I am analzying following case in Fluent. -> 3D -> Transient -> Mass flow inlet BC (Transient Mass flow, Always positive) -> Pressure Outlet BC (Static Pressure = 0 Pa) With the above setup, when i monitor the static pressure at the inlet, i am getting negative static pressure at inlet. Thus there is a negative pressure at inlet and 0 Pa at outlet. Technically, there should be a reverse flow, but Fluent shows no reverse flow. Also, as my inlet mass flow bc always applies postive value for mass flow rate, static pressure at the inlet should always be higher than the outlet pressure, shouldn't it?. But i am getting it completely opposite. Any comments why this is happening? |
February 17, 2012, 18:16 |
Rep Power: 15 |
static pressure is not the driven force for the flow but it is the dynamic pressure. If you set outlet pressure as 0, the inlet pressure can be negative because of the pgh, the hydraulic pressure. But it depends on the difference of the hydraulic pressure and the inlet dynamic pressure.
Hopefully it helps. |
February 18, 2012, 09:51 |
Rep Power: 17 |
Hi Nikhil
What is it you are analyzing? Regards Luke |
March 16, 2012, 01:17 |
#4 | |
banty
Rep Power: 14 |
Mass flow rate allow the total pressure to vary in response to the interior solution. on the other hand the pressure inlet BC, total pressure is fixed and the mass flux varies. A mass flow inlet is used when it is more important to match a prescribed mass flow rate than to match the total pressure of the inflow stream. so, if u are more interested with pressure then using pressure inlet BC may be good idea. Quote:
December 11, 2013, 13:16 |
Total Pressure
Manuel Díaz Brito
Rep Power: 13 |
Hi all,
I know I am joining quite late, but think that I can still contribute a bit. You should check the total pressure (static + dynamic), and recall that the dynamic pressure is , hence whenever the mean velocity is high, the dynamic pressure is so. With mass-flow-inlet and pressure outlet, Fluent will work out the pressure at the inlet for your flow to be possible. Verify that the mass-flow out matches the flow rate you are imposing, and should the computed pressure at the inlet not match your known pressure at the inlet, update the imposed pressure at the outlet (static and gauge) and keep your simulation running. Hope it helps, MDB |
December 11, 2013, 13:30 |
Rep Power: 17 |
Manuel has said already what i usually suggest to my folks:
-Check the total pressure / Mass flow -Check Convergence -Check your reference pressure (mean for incomp/ zero or mean for compr) |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 03:10 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 14:45 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
