how to compare unsteady state problem results from FLUENT with Experimental data?
Old   July 10, 2011, 09:25
Smile how to compare unsteady state problem results from FLUENT with Experimental data?
Selvam S
cuddaloreselvam is on a distinguished road
HELLO EVERYONE,
I have made a concentric heat exchanger setup in which water flows through the inner tube and steam in the outer tube. I am trying to study change in heat transfer for various water flow rates. Several trials are taken with different water flow rates keeping steam flow rate constant at a pressure of 2 bar. Here steam serves to maintain a constant wall temperature.
Now i am having trouble in modelling the same with Fluent since steam changes phase ( its in two phases ) as it passes along the length of the tube and should be treated as problem of unsteady state. How should i model this in fluent. Also how should i compare the experimental data ( conducted in steady state condition i.e. only the overall temperature increase is considered ) with Data from Fluent model of unsteady state.
Thanks in advance.
cuddaloreselvam is offline   Reply With Quote
cfd, condensation, heat transfer, steady and unsteady state, two phase flow
Comparison of experimental and CFD results for the VA-2 supercritical airfoil Aurélien FLUENT 3 April 24, 2024 11:39
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
using steady state results for unsteady flow siva appanna Main CFD Forum 3 February 20, 2006 06:29
Simulated data vs. experimental data moiami FLUENT 0 December 19, 2002 02:03
PhD in turbulence Hans Main CFD Forum 14 October 8, 2001 04:03
