UDF to define velocity, k, epsilon profiles at velocity-inlet
Old   July 8, 2011, 08:14
Default UDF to define velocity, k, epsilon profiles at velocity-inlet
aerospain
aerospain is on a distinguished road
Send a message via Skype™ to aerospain
Hi all,
I am using an inherited (being used by my current colleagues before I joined this company) UDF to define vertical (Z) profiles of velocity, k and epsilon at the inlet of a 3D domain.
As long as the Zmin boundary is set to zero, and it remains flat throughout the domain, I don't encounter any troubles. But, when this boundary plane is at a different height, say negative, and even if I change the Z reference value to that, I will get error messages in FLUENT as soon as I start to select the inlet as the reference location, or when I try to initialise the case.
Sometimes, I also encounter problems when my Zmin boundary is not flat and/or the inlet is at a negative height.
Any suggestions, comments, guidance?
thanks
K
aerospain is offline   Reply With Quote
unsteady inlet velocity udf jill FLUENT 8 February 10, 2015 07:04
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 10:44
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
