July 6, 2011, 21:37 |
Problem of cluster
Rep Power: 15 |
Currently I am trying to run fluent on a cluster of 5 debian computer. The problem is that when I launch fluent in command line with this command : fluent 3d -t2 -cnf=/home/****/hosts.txt (**** is my usr name) with host.txt the list on my cluster computer, fluent starts and then stop while it is conencting to the other computer. I think it is due to the fact that the other computer "don't listen" on the network for running in parallel processing. Also cortex is not running. So do you know how to fix that or what can be the source of the pb. Thank you in advance. |
July 6, 2011, 22:49 |
#2 | |
Engr Adeniyi
Rep Power: 16 |
Am not sure of what the problem is anyway, just try it if the .txt was a Windows(dos) file. Also make sure you have valid Fluent license on the systems. Someone with the experience would help if it doesn't work. |
July 6, 2011, 22:59 |
Rep Power: 15 |
I had tryed with different format and it doesn't work. The fact is that if I try on my local machine it is working, even with several processors. And it is not a network pb it has been checked too...
July 10, 2011, 23:51 |
Rep Power: 15 |
noone has a idea?
July 11, 2011, 09:53 |
Nikolopoulos Aristeidis
Rep Power: 15 |
what interconnection do you use?
SSh or Rsh? What fluent reports before crashing? if you cannot find out use the "nohup" command and create a screen.out file P.S. why did you set -t2 ??? this means 2 cpus. I guess you mean -t5 (or more) |
cluster, fluent, parallel |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 11 | September 4, 2024 05:28 |
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 08:30 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 15:52 |
