June 19, 2017, 08:33 |
#41 |
Rep Power: 12 |
Hmm... You are in a peculiar predicament here.
So just to be clear: you have a converged solution (residuals, monitors, maybe even animations point out in this direction) and you do not change any boundary conditions, models or URFs but saving files makes things go haywire? Could you post some screen shots of your residuals and monitors here? There is probably something we have missed. What are your URFs? Is your mesh quality suitable for the task? Have you had an animation of flow field of your calculation? Maybe you are simply in a point of calculation where the next iteration simply gives a different result. |
June 19, 2017, 08:46 |
#42 | |
yardena jodeck
Rep Power: 9 |
Sent from my SM-G570M using CFD Online Forum mobile app |
June 19, 2017, 14:35 |
#43 | |
yardena jodeck
Rep Power: 9 |
I attached and image. I couldnt before because I wasnt near my computer. I hope never have that problem you said because that would be fatal. Thats another simulation with a lower temperature. Now Im still iteraring so I will see soon the new result for fluxes imbalances. Ps. Good nick by the way |
June 20, 2017, 01:27 |
#44 |
Rep Power: 12 |
Thanks for the pic. The calculation seems to be quite stable also in my opinion simply by evaluating the couple curves presented in the picture. Maybe you could try to lower the flow Courant number to 20 and the explicit relaxation factors for both momentum and pressure to 0.25. These default values usually -at least in my experience- have caused some instabilities in calculations. This depends naturally of the case itself.
Additionally, you might want to update your Fluent to a more modern version at some point Fluent has become much more robust after R14 version. Oh, one more thing: I assume that the case where you took that screen shot had same kind of trouble with the saving and the mass balance. And I suppose that the current case has the same operational parameters. Last edited by divergence; June 20, 2017 at 01:45. Reason: additional assumptions |
June 20, 2017, 09:57 |
#45 | |
yardena jodeck
Rep Power: 9 |
June 26, 2018, 11:05 |
#46 |
MWRS
Rep Power: 8 |
Hi all,
I have a mesh of size 8 million. It converges the solution at 90 iterations. Energy, x, y, and z goes down to e-07, k and omega to e-05. My result in focus is CD and CL. The tolerance is changed for the latter two report def from e-03 to e-06. Still it converges at 90. LOL? |
January 21, 2019, 10:12 |
Apdl problem
#47 |
mahya
Rep Power: 10 |
Hello
I simulate a cylinder in ansys apdl I have this error solution not converged at time ansys apdl Please help me |
February 12, 2020, 11:18 |
#48 | |
Preethi
Rep Power: 6 |
June 14, 2022, 23:29 |
#49 | |
Vivek MJ
Rep Power: 5 |
convergence, fluent, mesh |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Time step dependence of convergence behavior of steady state simulations in CFX | Chander | Main CFD Forum | 5 | December 23, 2013 05:31 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
Defect correction and convergence | ganesh | Main CFD Forum | 4 | June 30, 2006 14:20 |
Convergence problems | Chetan | FLUENT | 3 | April 15, 2004 19:13 |
