Need help with Fluent Dynamic Mesh
Old   June 29, 2011, 06:24
Smile Need help with Fluent Dynamic Mesh
ZHAO Yuqaio
Bridges is on a distinguished road
Dear all,
I'm a starter on using FLUENT, and I got lots of difficulties.
Now I'm trying to learn dynamic mesh, and in the attachment is my first trial.
I create a circle with one blade inside. The tip of the blade touches the internal rim of the circle. I would like to try to make the tip rotates about the center of the circle. However, I couldn't make it. "Negative Cell" occurs every single time I ran the "Mesh Motion".
I hope that I could get some help here. Thank you guys sooooo much!
Bridges is offline   Reply With Quote
Old   June 29, 2011, 07:28
dmalcher is on a distinguished road
Hi Bridges,
I have a question to you at first. How do you implement your text file in Fluent. What you wrote is no typical UDF-Code. Did you compile it?
Try it with (omega_z 0 0 0.5).
(omega_z 2 3 4) causes a movement around all three axes (x, y and z). As your mesh is only 2D, you get negative cells at once. The unit of angular velocity is rad/s.
If the problem still arises, try to decrease your time step until it works.
Good luck!
Daniel
dmalcher is offline   Reply With Quote
dynamic mesh
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 09:27
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
FLUENT dynamic mesh set-up question ral007 FLUENT 0 February 15, 2011 13:28
Dynamic mesh + apaption in Fluent 12 ? klunker FLUENT 0 September 23, 2009 09:19
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
