June 27, 2011, 09:17 |
symmetry
hamid
Rep Power: 16 |
in simulating fluid in a pipe, in case of physical and geometrical symmetry and no turbulant, is there any issue for considering symmetry? is the result as accurate as in case we dont consider the symmetry and solve all the domain, ? what if there would be turbulance?
June 27, 2011, 12:11 |
trulytrue
Rep Power: 15 |
Dear Hamid, You should do simple case.
One simulation for simple full pipe with high turbulence , and the other simulation with symetry conditions in the middle (U are simulating the half domain).And comapre the results Let me know . Best Trulytrue |
June 27, 2011, 12:28 |
hamid
Rep Power: 16 |
thank u for reply, as far as i know for turbulence simulating, symmetry may cause wrong answer, is it also the case for laminar regime?
regards Hamid |
June 27, 2011, 14:09 |
trulytrue
Rep Power: 15 |
Do it in laminar as well, but for laminar it s ok
test by ur self, it s very easy and simple |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 04:13 |
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! | Cirion0000 | CFX | 0 | July 6, 2009 15:26 |
Forces in Symmetry | Matt | CFX | 2 | February 25, 2009 06:41 |
4 symmetry BC in a cuboid | Ralf Schmidt | FLUENT | 0 | November 1, 2006 17:29 |
Need desperate help again: Symmetry problem!! | Deadly | FLUENT | 0 | August 22, 2002 05:56 |
