June 26, 2011, 15:15 |
plotting
Mohan
Rep Power: 15 |
Hi
I have a surface that is rectangular and has holes in it, and has flow along its length. I want to plot the mean static pressure along it. Is that possible? Any help would be greatly appreciated, thank you. Mo |
June 27, 2011, 21:22 |
Mohan
Rep Power: 15 |
Please help...I'm desperate
June 27, 2011, 21:38 |
Tobino
Rep Power: 15 |
Is your problem in 2D or 3D. If it is in 3D you need creating some plane at Surface/plane in Fluent then you can report it OK belong to you. |
June 27, 2011, 22:03 |
Mohan
Rep Power: 15 |
Tobino, my problem is a 3D problem. It is essentially flow through a rectangular x-sectional duct. 1 of the surfaces has bleed holes.
I want to plot the static pressure along the duct, along the surface that has the bleed holes. That is already defined as a surface, as it's defined as a wall BC. |
June 29, 2011, 01:11 |
Tobino
Rep Power: 15 |
so, if you have got a surface you can be choice it at Report box and reporting belong your selection in box. I do not understand clearly your problem. please try again, good luck!
June 29, 2011, 01:28 |
Mohan
Rep Power: 15 |
i've drawn a simple image to explain what i need. hopefully it'll be clear now. i just want to plot the average temperature along the surface i've drawn. |
June 29, 2011, 02:00 |
Tobino
Rep Power: 15 |
Plot/XYplot/select your surface and chosen static pressure.
Free surface flow settubg boundary conditions and plotting velocity profiles | prashanthreddyh | FLUENT | 2 | October 21, 2015 10:58 |
Contours of 2D plotting | therockyy | FLOW-3D | 4 | December 22, 2012 16:04 |
Graph plotting | Lam | FLUENT | 2 | September 25, 2003 08:02 |
Plotting "in-plane" in 3-D | Karl Kevala | FLUENT | 0 | September 6, 2001 18:47 |
Contour plotting | Mark Russell | Main CFD Forum | 5 | April 22, 2000 23:45 |
