Heat Transfer from airflow to concrete
Old   June 22, 2011, 06:19
Default Heat Transfer from airflow to concrete
Mary2788 is on a distinguished road
Hi there,
I'm a relative novice to using Fluent and I wondered if somebody could give me some advice about a problem that I'm modelling.
I have a 2d setup with a channel of airflow beneath a block of concrete. Above the block of concrete is a second channel of air to represent a service floor, although there is currently no airflow in this space. I have defined the zones as fluids and a solid in gambit and I have set the airflow in the bottom channel to 0.1m/s and temp of 307K.
I was hoping to see the heat from the airflow move into the concrete and be stored, so the temperature should increase in the concreteover time. However, when I run the simulation the temperature across the whole space (including the concrete and service floor) stays at 307K and there is only variation of around 0.001K.
Please could somebody advise me as to where I am going wrong? Thanks for your help.
Mary2788 is offline   Reply With Quote
Old   June 22, 2011, 11:43
MadhuVC
madhuvc is on a distinguished road
is there significant temp. difference across inlet and outlet of the channels. what is the temperature of the channel wall( assuming you are modeling it as a wall). you can also verify your material assignment for different boundaries.
if you can do a rough hand calculation with respect to heat generated by the channel and heat required to heat the concrete, i guess you should be able to figure out.
hope i made some sense...
madhuvc is offline   Reply With Quote
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 17:29
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
