regarding the concentration contours in fluent
Old   June 15, 2011, 13:22
Default regarding the concentration contours in fluent
santhosh kumar T.
sandyouct is on a distinguished road
Hi everyone,
This is sandeep kumar, I did a simulation for a fire propagation in a room using a UDF as a heat source and got the temperature profiles but not the smoke concentration contours. Kindly anyone help me how to get smoke concentration curves in fluent.
Thank You very much in advance..
sandyouct is offline   Reply With Quote
Old   June 16, 2011, 04:32
Amir's Avatar
Amir
Amir is on a distinguished road
to generate something like smoke contour in this manner, you can implement a scalar equation, i.e. a UDS to involve convection and diffusion terms; also, you have to include a source term to this equation for regarding smoke generation or destruction as a function of temperature maybe.
Amir is offline   Reply With Quote
Old   June 18, 2011, 10:29
santhosh kumar T.
Hi Amir,
Thank You Very Much for your valuable suggestion and would you please send me any UDS if u have so that it would be easy for me to add all the terms that are required for my simulation.
send me to sandyouct@gmail.com
Thanking You in advance............
Old   June 18, 2011, 16:17
Amir's Avatar
Amir
Originally Posted by sandyouct View Post
Hi Amir,
UDS is a scalar transport equation which its template is available in FLUENT. It's just enough to activate that.
Old   March 31, 2012, 05:16
tsram90 is on a distinguished road
Hi everyone,
I am stimulating IC engines using fluent. Do you know the command to obtain temperature contours/ pressure contours in fluent.
like disp cont velo-mag 0 100 is for velocity
tsram90 is offline   Reply With Quote
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
Contours of density gradient in fluent 5? Ricky Wong FLUENT 3 May 19, 2015 02:39
regarding the gas concentration contours in fluent sandyouct FLUENT 0 June 15, 2011 12:40
Tgrid makes FLUENT contours messed up?? me3840 ANSYS Meshing & Geometry 1 May 13, 2011 08:26
Fluent: how to get the result on the concentration ALEX FLUENT 0 January 16, 2006 02:29
