Meshing and simulation of hydrophobic membrane
Old   June 3, 2011, 04:19
Unhappy Meshing and simulation of hydrophobic membrane
Vaibhav Gupta
vaxy is on a distinguished road
Dear members can anyone pls help me I am new to simulation in Fluent, and I am trying to simulate my multiphase model with following characteristics:-
1. Two channels adjacent one moist air stream with flow in -ve Z direction, one LiCl stream with some moisture content flowing in -ve Y direction.
2. Both are separated by a Hydrophobic membrane(porosity of 0.1 microns) which allows only water vapor from moist air to pass to LiCl stream.
Now I need to calculate Heat and Mass transfer coefficients.
Any help will be very grateful.
vaxy is offline   Reply With Quote
Old   August 1, 2023, 07:19
Zee
ZA
Zee is on a distinguished road
Hi, I am working on the same kind of problem i.e. liquid-to-air membrane energy exchanger. I also need to model the membrane for the moisture transfer from hot air to Liquid Desiccant.
Could you please guide me in this problem?
Thanks
Zee is offline   Reply With Quote
membrane separation, multiphase mixture
mesh generation for in-cylinder fluent simulation hennas ANSYS Meshing & Geometry 2 May 31, 2011 16:08
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
[Other] Meshing Techniques for Heat Transfer with Cube Shaped Objects cbritan OpenFOAM Meshing & Mesh Conversion 4 March 2, 2011 02:12
2D simulation - ICEM meshing for CFX question Ben Makhal CFX 5 April 11, 2007 09:44
GAMBIT meshing scheme rayy FLUENT 4 February 12, 2007 10:26
