June 1, 2011, 16:20 |
Always crashing when appending zones
Claudio
Rep Power: 15 |
Hello there,
I am trying to run a simulation using non conformal zone interfaces. However, Fluent crashes every time !!! I open the first mesh and I save the case file. I use Mesh>Zone>Append Case file and I append the second Mesh. Now, if I try to do the same (Mesh>Zone>AppendCasefile) in order to append the 3rd mesh, Fluent crashes . I have to save the case, close fluent, open it again and load the case file.When I do Mesh>Zone>Append Case file everything is fine and Fluent seems to accept the 3rd mesh. To sum up: I am trying to join 3 meshes using non conformal interfaces (similar to the example you can find in Fluent tutorial). I can only append 1 Mesh to a pre-loaded case file. Appending more than one mesh causes fluent to crash immediately. All the mesh seems fine and I believe I am not doing anything wrong. The only solution so far is to save the case file with the 2 appended mesh and append the 3rd mesh after re-starting Fluent. Am I missing something? thank you |
Skipping Zones | 1337Hal | FLUENT | 1 | June 27, 2022 10:33 |
merge zones | Domi | FLUENT | 2 | May 3, 2019 14:15 |
[Other] how to extract cell zones by cgnsToFoam | Ohbuchi | OpenFOAM Meshing & Mesh Conversion | 0 | July 22, 2010 05:19 |
about seperating zones | Bono | FLUENT | 1 | October 8, 2005 07:08 |
Patch-Different values to different zones | Pradeep | FLUENT | 0 | April 26, 2005 09:50 |
