Looping Over Cells in Parallel
Old   May 30, 2011, 09:56
Default Looping Over Cells in Parallel
patty
TedBrogan is on a distinguished road
According to the FLUENT manual, I should be able to loop over all interior and exterior cells on a partition using begin_c_loop { } end_c_loop. I should be able to loop over all exterior cells using begin_c_loop_ext { } end_c_loop_ext. However, when I use the first command, my udf only loops over interior cells and when I use the second command, nothing happens. Does anyone know what the problem might be?
I'm using windows 64 platform, is it possibly related to that? I need a way to communicate between to adjacent cells on different partitions. The macros above would make this incredibly easier than looping over individual cell faces.
thanks
TedBrogan is offline   Reply With Quote
begin_c_loop, parallel, udf
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
physical boundary error!! kris Siemens 2 August 3, 2005 01:32
