Span-wise summation of Fluent 3D data
Old   May 24, 2011, 11:13
Default Span-wise summation of Fluent 3D data
Ayan
ayannath23 is on a distinguished road
Hi!!
I am using Ansys-Fluent for simulating combustion case in a backward facing step geometry.
I need spanwise(along z) summed up value of heat of reaction in order to compare with experimental results.
From fluent we can directly get the heat of reaction values at each of the cells. but I need to do the spanwise(along z) summation of the 3D data.
Can anybody share some means of doing that?
Thanks,
Ayan
ayannath23 is offline   Reply With Quote
Old   May 26, 2011, 17:15
Default Easy.
sahm's Avatar
Seyyed Ali H.M.
sahm is on a distinguished road
Menu:
Report/Result Reports/
Then you have surface integrals or volume integrals.
Do you know how fluent calculates, heat of reaction? I cannot find it in manual.
SAHM
sahm is offline   Reply With Quote
Old   May 26, 2011, 17:36
Thumbs up
Ayan
Thanks for your reply.. But Report/Result Reports/ does'nt gives spanwise summation It can give heat of reaction values at one or multiple plane (or line etc)..
But i have got a solution for my problem. I have created multiple planes in spanwise direction & have exported the heat of reaction data on those planes to Tecplot. In Tecplot I'am able to do the summation of the datas..
Regarding heat of reaction calculations in fluent, I have used the Fluent Manual only as of now. So don't know the calculations in details yet.
Ayan
How to link Fluent and MATLAB and exchange data? z701531118 FLUENT 3 October 9, 2013 15:26
Conversion of Data file to FLUENT sanjibdsharma OpenFOAM Post-Processing 5 September 9, 2011 07:13
rearrange Fluent data distribution IvanCFD FLUENT 0 November 6, 2009 14:09
Importing Gambit data into Fluent Tyred ANSYS Meshing & Geometry 1 April 18, 2009 14:53
Problem of import fluent data to ilight fieldview seasoul FLUENT 3 September 9, 2008 23:36
