May 22, 2011, 10:43 |
Complex multiphase melting problem
Rep Power: 15 |
The problem i'm dealing with involves the pouring of molten steel into enclosure which contains an aluminum block. I would like to simulate the melt process of the aluminum block by the molten steel. In such case, it becomes a 3 liquids problem (molten steel, molten aluminum and air). Is FLUENT capable of performing such calculations? I would appreciate your help a lot!! Thanks |
flow, free surface, melt, multi phase, vof |
Gambit - Mesh Problem for a complex 3D geometry | Nelson | FLUENT | 3 | May 28, 2012 07:57 |
melting problem | bk | Siemens | 3 | November 8, 2005 17:15 |
Problem of B.C. in Eulerian multiphase model | Derek Jing | FLUENT | 0 | May 12, 2002 12:52 |
MELTING PROBLEM | Przemek | FLUENT | 1 | April 17, 2002 04:22 |
CF4 - need advice on setting up multiphase problem | Brett Towler | CFX | 2 | August 18, 2000 17:38 |
